best trim. Wammer/virgin or ski clinic
Anyone get a chance to run either of these systems at tona to compare? I was impressed with how easy the wammer trim pulled while putting a little force on the nozzel,not sure what it would feel like under WOT
parrdaddy
No he will not!
My vote goes to Virgin :hail: Don't mess around with the easy pull, the straight pull is easy enough......if you can hang on, you can pull the straight pull too :biggthumpup:
The ski clinic system is very nice as well, but 1) I don't think they are selling them yet??? and 2) the installation has got to be much more tricky.
wammer trim
the wammer trim is easy to install ,reliable,and simple by design
under wot there is some resistance,you should try it first
yigal
tom21
havin fun
clearwater FL
I like the one #0 designed and I welded. its simple and works smooth. cable is straight and can be adjusted. I even worked out a way to have the cable mount so it doesn't move sideways when operated.
One thing I did notice and have taken for granted all this time is you need to flip the pump (vein housing) upside down to clear the steering cable. duh all this time and now its so obvious- head still hurts from smacking myself upside it.
So no one has first had experience with the ski clinic trim yet? I was suppose to meet him at the flat water clinic to ride it but just couldnt break away from the surf,I was really surprised he never brought it out in the surf.
pardaddy.how much easier is the easy pull under throttle,I dont need a ton of trim just a bit and super easy to pull,Im uncomfortable having to grab the lever with all 4 front fingers.Ive tried the blowsion trim on a ski under decent throttle,it sucked hard. I may need to try one of these before I drop the cash.
Idok... I know I wont need it for every big deep wave once I get the backie dialed,but I have some plans for some other conditions:splatt: but if you rock out and pull one without trim in the shallows I promise ill follow.....lol
