Backfire-no start
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Make sure you use only new genuine Mikuni rebuild kits and needle valves.
When you replace any of these items...Tip: make sure you use a single edge razor blade and set the float arm just barely below the float chamber flat boss.
Call Radney @ the shop...we should have plenty of those parts if needed.
UPS is only 1 day to Jacksonville/St Augustine.
Chuck
FlightPlanDan
Don'tTrustAfartAfter50
Chuck
Talked to Radney this morning. Shipping today. Thanx Chuck.
FlightPlanDan
Butti called it on the beach. SUPERTUNE called it on the X. The "o" ring of the slave carb's seat was wasted. Gas was flooding the crank case after shutting off causing backfire and no-start. When I pulled it apart the seat was super loose.
Have not put it back together yet. I will In the a.m. Will only know for sure then.
