Back to stock pipe from Riva red, Jetting?
Hey folks, I have a bit of a unique situation. And am hoping to draw an opinion from people with way more experience since I only really know my setup.
Looking for a decent place to start regarding jetting.
Going from red pipe back to stock exhaust.
Jetting with the red pipe: single stock 44 carb, 2.0ns, 120/150 jets 95g spring at sea level, primer, stock electronics
Engine: Cyls are ported, thin head gasket ~160psi, bored up a couple sizes ~735cc
I also have a stinger for the stock exhaust that I’m thinking I’ll put in.
Am I good to run the cab setup as-is or should I drop it down to 120/140 or 120/137.5?
Thanks lads, trying to get this girl back in the water asap!
Nobody else running ported 61x cyls on a single 44mikuni and stock exhaust with a stinger? LOL.
Plan at the moment is to step down to 140 main, keep the 120 pilot and 2.0n/s with 95g spring. I'll report back after I get time to head to the lake for some tuning.
dfw
The top screw adds fuel so you can adjust the mixture. A 150 main will probably be okay with the screw closed. If not then install a smaller jet and retune. Either way you must learn how to tune your carb since every engine has different needs.
Take a look in here there might be something there , but yeah your setup is not that common on a Superjet , maybe on a Waverunner lll or a VXR .
Ya I went through all 26 pages of the database and couldn't find anything ported/ stock pipe. I'll fiddle with it next lake day and add to the database what I come up with.
Anything added to that thread would be a good thing for future reference.
