Your cyl. should be a 61Xcyl if it is stock... You should have no problems
You are probably reffering to your 62t cases. all SJ's came with 61x cylinders. The manifolds for B1's and Sj's are the same, but the limited B1 pipe like the one I have for sale, is only for a Blaster, I dont think it will fit in a SJ.
Better than hogging out the bolt holes on the manifold would be to use 'Timecerts' if you do have a 62t cyl.
You will not really be able to use the manifold again on a 61x cyl if you enlarge the holes for a 62t cyl. I have the timecerts in my 62t cyl for my 61x FP manifold.
