- Toronto, Canada
How much space have you given your b-pipes? I noticed that mine had developed a gash from having the bedplate vibrate against it. It looked like it was spaced well before I ran it....
Is 5mm above the bedplates/flywheel cover, and 2-3 mm from the port side of the hull enough? I can easily run a thick piece of cardboard down the side between the pipe and the hull. Should I start denting?
Christian
Christian
