faster7581
Raceaholic
- bradenton, fl
anyone make 83mm flat top piston?? for yami 701
No.... they start at 84mm.
The only way to use a flat top in a Yamaha, is to re-sleeve the cylinder, machine cylinder 4mm shorter, then machine a Kawasaki small pin piston Part # 813M08300.
My question is why do you want a 83mm flat top piston?
If you want power from a Superjet, go for bolt-ons first, then consult a specialist for a properly built setup from there.
its for a blaster for spec class, cant be over 83mm, already have a limited pipe, 46 bucks(looking for novi 48's) riva manifold, msd enhancer, ADA 33 domes( can only run 185 psi) so i figured flat tops were next.. i found wiseco's made for a yamaha, ADA makes drop in flat top domes for them, but pistons start at 85mm..need 83mm , dont want to go kawi pistons, can't modifiy the cylinder per rules..any other ideas?The only way to use a flat top in a Yamaha, is to re-sleeve the cylinder, machine cylinder 4mm shorter, then machine a Kawasaki small pin piston Part # 813M08300.
33 cc domes should put you in the high 190's or 200's depending on which cylinder you run(61X or 62T). 35 cc should put you in the range you are looking for. Pm me and I may be able to bounce some ideas to you that may help you out. Long time no see Mike. I don't think I have talked to you since 97, when wade was still in the business. Rocky point M.D. I think you were on the armonds HX. Time flys..................
JAM
flat tops make a liitle bit more hp.. not a huge increase.
According to some builders...... Since a direct comparison(with no other variables) between FT and domed motors is almost impossible, the flat top theory is really only a theory. Flat top motors don't always produce more power over otherwise similar domed motors and the reverse is also true. I personally believe the expense and complication of flat tops makes any (possible) small advantage they(might) provide negligent. Plain old Wiseco yamaha pistons are available from almost anywhere and at reasonable prices. I challenge you to ride a well built domed motor and feel or measure the difference. There are so many other factors that make bigger differences. IMO the flat tops are just another distraction(and expense) that don't produce results equal to the hassle involved. FWIW, if I was building a Kawi motor I would absolutely use flat tops since that what they come with. I don't believe they're bad, just nothing special. Just my opinion.![]()
