Looking for help on getting some information on this motor.
I have looked around online and haven't been able to find anything similar. I purchased a 750SXI ski that had a lot of aftermarket modifications, first the motor was definitely big bore and height of the cylinder case suggested it was a stroker as well. The engine top end has a Westcoast head with removable domes, however its not the typical westcoast head you see on other 750 and 650 motors. The cylinder case is also westcoat and all the through bolts which attach it to the crank case are internal like you would see on a Dasa. The piston size is 89.5mm and the stroke looks like it is about 78-79mm which puts the displacement around 980cc.
Other main performance mods that the ski came with:
Factory Wet Pipe w/ resonator *(thanks The Buzzard)
Dual 46MM buckshot carbs on R&D intake
Aftermarket ignition w/ lightweight flyweel (Bad Bone or something like that)
The ski pretty dirty when I purchased it however it did start up without too much trouble and ran fine. I have stripped the hull, disassembled the motor, and now I am just waiting to paint the ski after I finish the footwells.
If you have any information regarding the motor setup please let me know.
