- Michigan
Hi guys,
I recently purchased a TDR waterbox to go with my Factory B Pipe. I installed the waterbox with no issues but noticed that the sled was not performing very well. It was not going into higher RPMs. It was running like it was a fuel tune issue. Does the water box need to be at a certain elevation when installed? Just curious because the TDR box is significantly smaller than the OEM box. I have stock 38 mm carbs as well, so could they need to be re-jetted?
Looking for your expertise.
Thanks,
Ben
Thanks,
Ben
