- California
What are the actual compression numbers?
I would also test it for air leaks.
the650 fiberglass waterbox will be fine , but it sounds like you have a leaky needle and seat, hence why the plugs are loading up really bad. be careful, a bunch of extra fuel / fumes in the engine can cause a backfire on startup. one good backfire will blow the waterbox to pieces
