Advent ignition settings???
I have a Kawasaki SXR 800 - yearm -08
I have a tempest3 model 2734 ignition ,
I have made some modifications:
Factory pipe - dry pipe
ADA Head - 28 cc domes
Vforce 3 valve system
skat trak C-75 Swirl impeller 14/19
I'm riding freestyle - so I would like the best setting for that.
My weight is about 62 Kg - 136 lbs
How do I set the ignition for the best setup???
cmeripper26
Ripper26
Connecticut
That ignition setup is the same as i run. I have a lot of bolt on mods from carbs, head, pipe, air cleaners, my Curve set is D14 for this set up i run the timing curve #3 set for an OEM motor and this setup tears ass.... it's an arm puller once you get everything dialed in. You only use Switch A, and the timing curve is set with #6 & #7 on switch A. Go through the factory curve sets that came with the CDI and look which motor set up best applies to your motor and start with that timing curve. Just be sure your not cooking a hole into your piston after you ride a little.
