Adjustable water bypass
Christian_83
Xscream
Denmark
a Flow Control Valve is something completely different.
Its close below xx psi, and opens at xx psi, its used to keep the waterbed empty and not loading up with water at starts and low rpm.
With a ball valve, you can adjust the flow, so decrease the water flow to increase engine temp. Increase water flow to Decrease engine temp :)
