norcal ex
X-H2
- San Jose, CA
How much is this engine worth?
ADA cylinder , ADA head, and domes -- PRO-X pistons, and a RAD light-weight crankshaft that is 73 mm of stroke --
cases are port matched to cylinder and epoxied --
everything is fresh -- crank was just re-done ( has zero hours on it) by crankworks -new bearings (koyo), new rods, and new rod bearings, also trued and welded.
The pro-x pistons are new and are 85.5 mm , with the 5 mil stroke make 840cc.
It is a great set-up, makes awesome power from the bottom all the way to the top.
