mk1
PUDDLE - BLASTER
Guys , which head is best for a standard motor fx1 , ada or blowsion. Are they the same , about to place an order , so need to know... ! (thanks)
Have a protect exhaust , switching over to a b pipe...Are you running stock exhaust. If so you have to buy an adapter..... Not sure if Blowsion sells one. Go with ADA
No adapter is required with blowsion, head is tapped already.
As I plan to use new head with b pipe , which head do you think would work best.... ?No adapter is required with blowsion, head is tapped already.
Thanks , will check it out..Either head will work. Jetmaniac had a really nice Blowsion for sale the other day.
