ADA head 650sx cooling?
I have a project i bought a few years ago. Been a slow build, but the previous owner had purchased a ADA head for it. Just wondering how i should run the cooling for it. Will be running stock exhaust with the dry pipe mod, and silicone Joint rubbers. (cant think of the name at the moment). It is tapped for dual cooling coming off the pump. Two 3/8 lines coming into a splitter 3/8 to a 1/2. Then 1/2 inch into the manifold. As of right now the factory pisser port on the Elbow has been left open as stock. The drain port in the back has been sealed. Here is a pick with out any lines of what i have. The 2 knobs on the top of the head are the water ports on the head. Let me know what you think. Thanks
