- Bakersfield
does anyone run 33cc domes?
if so how much of a difference is it from 37cc?
im running a bb 781
im running a bb 781
Check your compression and call ADA. They will dial you in on what size you can run. Also, if you are not running it wot, pump gas is OK. But if you keep it pinned for a while detonation meltdown may occur. So you may have to get a bit higher octane, but I'd check with your builder too, just to be safe. I have an extra set of ADA 760 33cc domes if anybody is looking. Also a good idea to know what your squish is. So to get it all in order. Call builder first, then maybe ADA depending on builders recommendations. Your builder should know your squish, if not it's a very easy measurement for anybody to do. Powerfactor told me how to do mine and it's a cakewalk. End of confusion. 33cc domes available.
I'll hold them for you NP. But give the builder a ring first and see if this is the ticket. Shoot me a text when you find out what's up.price?
X2Id talk to your engine builder first
Totally true. Everybody has a different set up. I'm also same elevation, but 31cc domes and 165 psi. Porting is different in our motors. (Chris's is better lol) I'm working a deal on some 27cc domes now to get me to 195 psi, so my pfp will run right. Higher elevation is a biotch!Depending on your porting your compression/dome size will change as well as your altitude, we are running 31cc at 4500 Feet with 91 Octane and 33cc at sea level with 91 octane
