Ada dome suggestions
kkwedell
x-h20.com
Walnut Creek
So I just had my 701 bored out to 83mm and I have a couple questions. Right now my compression is 205 with 33cc 701 domes. Can I run 760 domes just in case I want to go bigger in the future. If so what size should I go to get around 180 psi. If not what size 701 domes should I get to be around 180 psi, I was thinking 37cc. Thanks for the input.
Sent from my SCH-I535 using Tapatalk
My 735 ( 83mm) had 205 compression with 35 cc domes at sea level. I switched to 36 cc domes to be safe but probably didn't need to with 93 pump gas we have in Florida. Your compression should be higher than 205 unless you are at a significantly higher altitude. You could have your domes cut to 34 or 35 if you are concerned. There are alot of builders around that could modify them for you. 205 is not that high if you are just brapping around and aren't holding throttle wide open for speed.
BruceSki
Formerly Motoman25
Long Island
Hey freakie, 215-220psi at sea level on my gauge @82mm stock bore (unported) 701 with 33 cc domes. She rips wide open for minutes straight through the inlet and the marsh!!! 93 pump octane from Mobil or Shell.
kkwedell
x-h20.com
Walnut Creek
I went with 36cc 701 domes. Safe to run with 91 octane gas? Sometimes I do rip wot around 10 seconds.
Did you read what BruceSki runs and how high his compression is with 82mm bore ? Your 205 compression was not up to par with 33cc domes at 131 elevation where you live in Walnut Creek. You must have a worn or scored cylinder unless you have race porting ? Have you inspected your cylinder, something doesn't add up on your numbers. Is your compression gauge of good quality? Battery and connections good?
JetManiac
Stoked
Vendor Account
orlando
Comparing compression numbers is only a rough guide. Different guages, different testing methods(throttle open or closed, plug in or out), battery condition will give a fairly large range of results even on the same motor.
There are many other variables as important like squish, hull type/weight, and timing advance/retard.
