Custom/Hybrid 97 Superjet RN build
Superthreat
grip it and rip it
Bc canada
Blowsion stubby cone installed
Plastic Intake Duct removed.
Aluminum Intake Duct installed.
Jet pump unit cleaned up and re-installed. 9/15 hooker imp
New pump wear ring.
New Gelcoat
Superthreat
grip it and rip it
Bc canada
Cleaned up drive shaft coupler and re-installed.
Hull Re-enforced with fiberglass
Used 3:1 epoxy based resin
Biaxial Cloth for first layer, Stitched cloth for second layer for a smoother surface/look
Inside of hull painted white.
Superthreat
grip it and rip it
Bc canada
Installed steering cable
Installed new steering cable packing kit, and replaced missing stainless washer
Superthreat
grip it and rip it
Bc canada
Build a couple of jet ski stands out of 2" pvc
Gonna use 3" caster wheels so i can move them around
Built them to the height of my tailgate so i can self load/unload
Superthreat
grip it and rip it
Bc canada
Thanks!
On the Aarow Lake, Kootenay Lake, Or Columbia River. I usually launch in the Columbia River. its like 5 mins from my house.
What about you?
Superthreat
grip it and rip it
Bc canada
Finally finished the jet ski last summer. A big thanks to Jetmaniac and Wamiltons for all the help and parts.
Here are some pics from the build.
Ski Setup:
62T crankcase
61X Cylinders
Freestyle ported (by Blue), bored to 82mm and exhaust/head decked
New Pro-X top end with new pistons, rings, and wrist pin bearings
Lightweight flywheel 62T
Girdled head(pro design)
Factory b setup with dual cooling
Msd enhancer
V force reeds
Twin 38 mm mikuni carbs
After market waterbox
Jetting
137.5 main, 75 pilot, a/m flame arrestor- 95g springs
Other new parts
New Rebuilt Crankshaft by SBT
New engine gaskets
New OEM crank seals
New crank
Clean used 62t stator
New Bendix drive and hardware
New Blue Factory pipe coupler
New waterbox 90 deg hose. blue
NewSilicone Long exhaust hose -waterbox to bulkhead outlet. blue
New Voltage regulator/rectifier
NewFuel Visufilters
New coil and msd plug caps
New e-box
Superthreat
grip it and rip it
Bc canada
Turned over first try!!
Built a pvc tray for the truck
After breakin period, this thing hits hard.
New hood and paint job (yamaha blue)
Custom decals added
