- ark
93 Superjet Won't StartI have a 1993 superjet that was running like a champ until I went out to the lake the other day and it got submerged. As soon as I got it back to land I flipped it over and got all the water out of it and restarted it and ran it till all the water was out of the engine. It seemed to be running fine until I got it home and it wouldn't start again. It will turn over fine and the compression is almost perfect, its getting fuel to the spark plugs, and most of the time will just about start up but die before it starts up. I checked the spark and there was barely any there so I opened up the ebox and the cdi was wet, I ended up ordering a brand new cdi that I got the other day. What else could be the problem if it is not the cdi? I also don't really think that it would be engine related since compression and fuel are both good. Thanks!!P.s The fuel has been dumped and changed. I replaced the cdi and nothing changed. Should I order a new coil? Ill open up the stator case today and see if it has water in it and put the results on this thread.
