84mm Bore
brentR
way fast whitey
Toronto
So correct me if im wrong - i just bore out my 701 61x to 84mm bore... i have to run a 760 dome and a 760 84mm pro-x piston?
Phill
v Check out Little Matt_E
Kennewick, WA
Dont forget that the stock sleeves get thin at 84mm. Some builders will say not to run 84mm on a 61x with stock sleeves.
brentR
way fast whitey
Toronto
whats the worst that can happen? lolz
if I did 83mm i would have to run the same domes but with 83mm pistons right?
No, aftermarket 701 domes and even the stock 701 head are good up to 83mm. Just check squish.
