D-Roc
I forgot!
- Dirty River Rider
werd!
The difference between a stock cone and a wet wolf cone should be more than hardly anything at all specially if you think you have too much impeller. Maybe you have other problems contributing to this symptom and not just the impeller.
oh man, you need to put the timing curve on, no wonder your not happy. do it up, that motor would have popped if you assembled it wrong by now.m glad to hear your getting performance gains by tuning your entire ski. keep it up.
Its pulling way harder but there still isnt that punch, On my first tank of gas I wouldn't have been able to do a nose stab, and I'm not even kidding, This weekend with Changing the ride plate, WW Cone, Moving the restricter and burning more gas it sure has woken up. I would say last year had more arm wrenching punch then this year but its been gaining power so slowly I could be entirely wrong and I'm just used to it... But I have ordered the 10/16 and no matter how hard this set-up is or isnt hitting I'm still going to run it for a weekend... If it has more punch then the 11/17 I might not return my 11/17 but see if Dave can do an in between custom re-pitch somewhere in the middle of 10/16 and 11/17...if I loose some punch I'll go the other way towards a 9/15... I dont know if that is possible at all just seems like a good idea...I dont know nothin about anything when it comes to impeller pitches/pitching lolMaybe that 11/17 isn't that far off then?
Munkie,
I ran a 9/15 Hooker on my Dasa 760 and it hooked up good. I had a blueprinted pump, WW cone that changed to stock, bored 85mm nozzle and a aquavein intake. I was real happy with that setup and had bottom end hookup. My Epic was programmed by Art so I don't know the curve, but flyinb501 has it now and he can pass on the curve if he's got the software. Art was spot-on with that curve.
