760 not starting
I've got a 760 that will start if you put fuel straight down the carbs but will not start off gas from the tank. It is pulling gas to the carbs and I have cleaned the carbs several times and have not found anything that seemed to be blocked. New gas and spark plugs. Any suggestions?
Quinc
Buy a Superjet
California
check your one way valve, reeds, and that your fuel lines are hooked up correctly. Also disconnect your fuel selecter switch if you are using one and run the lines straight to your carb.
same concept just run the reserve line as the main fuel, that way it is all the way to the bottom of the tank. make sure your jetting is at factory specs and spark plugs are cheap so it never hurts to try and fire it up with new plugs haha. goodluck im close to having my 760 put together!
