760 jetting
Q
QuickMick
Guest
Im building a 760 for my blaster. I would like some opinions on where to start jetting this motor for the mains and pilot's.
It will have the following:
ADA head 38cc domes around 180 psi 93 octane
84 mm pistons
dual stock 44's
Limited B pipe and water box.
Thats pretty much it.
Thank
oldskoo
local jackass
Cleveland Ohio
port it!!! or you wont be happy...760s just dont have the hit of a 701 down low in stock form...i know iv sceen me do it........i run 38's so my jetting wouldnt be the same but im running 140 mains 70 pilots 95g springs.........
Q
QuickMick
Guest
anyone else?? I know someone out there has done the same build.
guiness92
Here is the jetting on mine. I have:
760
84.75 pistons
ada head, 38cc domes 190 psi comp
Dual stock 44's
Bpipe mod chamber
Pretty heavily ported.
Main 130 H adj 1 turn out
Pilot 127.5 L adj 1.5 turns out
1.8 N/S w/ 95 gram spring
Not exactly the same, but could help I guess.
Q
QuickMick
Guest
Whats your altitude Mick?
I am pretty much at sea level. maybe 20 feet???
Im getting good advice telling me to start at different jetting sizes. I dont know what to do.
THanks for the gasket hookup though.
