760 dual 44's or Black Jack dual 46?
SuperJETT
none
thanks Jett.
BUt I wasnt clear.
Im confused as to OEM, and REGULAR 44s?
if OEM carbs come on skis from the factory, where do REGULAR 44s come from?
From Mikuni, the oem's would get carbs built specifically for each engine. They are the same basic carb but with different calibrations.
dfw
You're asking about some top secret stuff (lol). The answer is extremely simple once you know what to listen for.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Throttle plates are wrong too...I know some people have gotten the OEM's to work OK for their setups, I was NEVER happy trying to get them to be consistent and make the HP.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Not worth the effort for me...I can buy new Mikuni 46's, reprogram the jetting circuit, setup jets and popoff and they're ready to go and always run good. Or for the more serious power heads...We use 49mm Full Spectrums.
I thought there were guys out there running 44 mm blackjacks that were made out of oem 760 carbs and they were running good. Maybe they change the throttle plates and reprogram the jetting circuit as well.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
I've asked this question to Art before and the answer was that he could make Black Jacks out the OEM dual 44s as well as aftermarket Mikuni. He said it did not make a difference and there is no difference performance wise after he gets done with them, just major light switch BRAP!
