- South NJ/Tampa FL
very nice work
OK! So after some figuring, here is the new steering linkage extension I made:
This was picked up from True Value:
5mm threaded rod
5mm lock washers
5mm nuts
1" aluminum sleeve
5mm x .80 tap
Steering only needed to be extended roughly an inch. So I tapped the sleeve .5" one way and .5" the other to jam the two ends together. Then after threading .5" into the sleeve, i measured 1" from there (only .5" threads into the ball reciever) and cut the rod. There is my 1" extension. Feels strong, but we'll see how it performs under a load with the jet running.
One other thing I figured out, if you move the ball to the bottom of the nozzle, it completely removes the curve that happens when you use the trim. Straight up and down now.
Below is a final video of the setup:
