- Jourdanton, Texas, United States
Well this what I have. 95 750sx, small pin motor, std. bore, coffman sizzler, r&d intake main, 9/17 solars, ocean pro cone, R&D intake grate, and ocean pro ride plate. The problem I am having is there is a delay in the engine when I try to punch it while I am riding. I am running a 46mm blackjack and I have heard that these carbs can be bad about this. My jetting right now it 120 low, 155 high, 2.5 n/s at 20psi. I has good topend but my bottom end just has the deal in it when you try to punch it at low rpm's. I have been reading that if I go down to a 44mm this could fix that problem. What do you guys think and do yall have any suggestions? Thanks.
