Hey guys,
Have this 02 750 sxi pro. Haven’t run it for a few years. It got some rainwater it for a few months while sitting. Now it’s time to start wrenching and get back to riding. Seems like I got a lot of work to do.
Old battery was toast so Put in a new battery still nothing (no click). Started going through it and cleaning up connections. part of the exhaust is off to make this easier.
Before jumping the solenoid Decided to try and turn the shaft with the plugs out and it won’t budge. I’m trying to determine if the engine is frozen or if it’s the shaft bearing. The shaft is between the coupler and the impeller so I’m leaning towards the bearing being bad.
Before getting a bearing rebuild kit and pulling the motor is there anything else that should be done to diagnose this or get the bearing spinning without pulling the motor?
ski details-
02 750 sxi pro
aftermarket intake grate and isolas prop
Previous owner had it bored out
MSD, lightened fly wheel, total loss ignition
factory pipe
ski details-
02 750 sxi pro
factory pipe
