750 SX/X2 questions
Snackem
Danger Zone
Colfax WA
That would make sense. I'm sure that I have some top end damage since my compression is only 135. I was reading my build thread and when I acquired the engine I had 135 psi in each cylinder and last night I was at 110.
I wonder what was causing the detonation? Any suggestions?
I was running BR8ES plugs
Compression was 135
Stock 650 electronics
93 Octane mixed 40:1
Any ideas? I am going to pull the head off on Friday afternoon, hopefully I'll be able to get some pics and post them then.
Crab
thanks darin...noswad!
Seattle
First off, try another guage, use a bigger battery, and make sure the carb is wide open when cranking. I would be more inclined to tell you the coil may be bad, or the plug wires need cutting back. I have had 2 coils do the same thing, my 3rd one ran all weekend without a hitch. New B7ES plugs wouldn't hurt either.
Snackem
Danger Zone
Colfax WA
I tested again tonight and found 110 in the rear cylinder and 120 in the front. I'm going to test again friday w/ a fresh battery and then open up the e-box to see if there is any salt or water in there.
After that down to the river and try to duplicate the symptoms again.
