- Ocala florida
Need cylinders ported asap or 701 porting templates pleasee help asap!!!!!!!!!!!
I have factory dry pipe westcoast head 175-180 compression stock prop i just want alil more bottom maintaim top speed thats why i still have stock prop i do lots of lake riddind no trick ridder just jump a few wakes and across the lake im a newb so im still learningThe big question is what are you looking for from the porting?
The DIY template is great and it is what I did to mine but it is only the exhaust port you are changing and the big hindrance on the 701 cylinder is the transfer ports.
So the DIY is good but will not match the performance of having a professional actually port your entire cylinder.
No, do not touch them as you can ruin the cylinder. The transfer ports should only be touched by someone that has done a lot of porting and knows the 701.Are the transfer ports not matched up ifso thats something i can do myself im very mechanically inclined
Old 91 snNo, do not touch them as you can ruin the cylinder. The transfer ports should only be touched by someone that has done a lot of porting and knows the 701.
I would suggest the first thing you do with all those mods is get the correct prop on it. What year is the ski? The newer ones had pretty good factory impellers.
Post #6, He is already running a Factory pipe and WestCoast heat with 180psi.Before you even think about porting, you need to be running a good prop like a hooker and a girdled head with some higher compression and a good pipe. That alone will make an absolute massive difference.
What are your current mods?
Oh okay! Yikes that's a lot of power going to waste. Lol he's gonna freak when he rides with that new prop.Post #6, He is already running a Factory pipe and WestCoast heat with 180psi.
Absolutely agree on the impeller.
Omg its been like 3 days!!!! Did someone get your cylinders potted yet?!?!? Plleaaasseee let us know ASAP!!Need cylinders ported asap or 701 porting templates pleasee help asap!!!!!!!!!!!
I sent him pot templates and a materials list in the arts and crafts section so hes on it, no need to be a bully chill he says its already in the pot and has sparkOmg its been like 3 days!!!! Did someone get your cylinders potted yet?!?!? Plleaaasseee let us know ASAP!!
