701 or 760
You will find that the majority of people recommend the 61x 701 cylinder with the 62t cases. A good build would consist of the following...
61x cylinder
62t cases
ADA girdled head
factory B pipe
650 flywheel/stator
single intake adapter w/ 48 carb (or dual 38s or 44s, depend on budget)
or... use 61x cases if you are just keeping to a real strict budget, with a 44 sbn.
There are TONS of threads about all this, but most people suggest 61x cylinder, 62t case, ada head, and B pipe.
cambo au
TRYING TO LEARN
AUSTRALIA
i have a 62t 61x with my own porting (just the transfers cleaned up and exhaust polished) twin 38s and b pipe and it hits a hell of a lot harder than my mates 760 with the same mods i think 44s would be better but have not got there yet there will be mixed opinions on here but my vote is 701 62t 61x
i like the 61x also. but crammit442 had his 760 motor reported by jetworks. :bigeyes: hits harder then any ported bb ive riden . arts got it going on. some of you guys are really missing out on some raw nasty power. glad my ski is powered by the man.:cool2:
SUPERTUNE
Race Gas Rules
Clearwater Fl.
Start with a 61X cylinder w/62T case, stock is a great place to start w/ bolt ons
Then step up to Big Bore re-sleeved 61x cylinder.
And yes! I've also been called "Your The Man" too...
P.S. see the reason in my sig.
CoreyLKN
LKN Freestyle Militia
Lake norman, nc
Chuck,you a phone number so i can give you a call and talk about some motor options?
njfl
X-H2
apparently the 650 flywheel is the lightest OEM, correct me if I am wrong?
Haven't weighed them, but even so, the 650 and 701 (61X) flywheels and stators are the same, so a 61X 701 setup will work too, but I believe the 701 CDI has a higher rev limit than the 650, so look for a 701 box.
Mile9c1
X-H2O.com
Grand Rapids, MI
The 650 and 701 61X flywheels are the same, they are slightly "lighter" than the 62T flywheels.
Bore a set of 61X cylinders to 84mm and then you have a nice 760 :biggthumpup:
Boris
The Good Old Days
I have 1 62T 760, 1 62T 701 and 1 61X cylinder on a stock bore.
From what I'm reading on here I should dump the 62T's and use the 61X.
However, there are those who swear by the 62T.
The more I wait the more confused I get. :dunno:
WaveDemon
Not Dead - Notable Member
Hell, Florida
I'll be happy to take everyone's 61x cases and 760 or 701 62t cylenders off your hands then. I"m in desperate need of boat anchors.
