Blaster 701 crank bearing roar
MA
Put my bottom end together last night and while moving the crank its a little noisy. The crank that I am using had a front cylinder meltdown, so I tried cleaning it with break cleaner. I then put the crank in and poured a large amount of oil down the 4 holes. All the holes except the front one will flood quickly and slowly drain, the front pretty much goes right to the bottom of the case.
