SJ/XPBri
Just SJBri = no more XP
- Northern, NJ
No oil in the gauge, I understand where the solder needs to be placed. The problem with the solder- the piston is kicking it just far enough away from the cylinder wall to get an accurate reading. I am going to be running the ski on powermist 111 race fuel, hopefully it'll give some added insurance. If this thing bends a rod, it'll be OK, I'll have some pics for the carnage section. I'll keep everyone posted on the results :biggrin:egbrig said:When you measure the squish where are you putting the solder, it matters, there is a proper way to do it or your going to get messed up measurements. PSI compression readings is not what matters. Its the mechanical compression ratio that counts. Too many factors come into play when talking about psi readings, psi readings are indicate the condition of seal between the rings and the cylinder wall. Also did oil get into your guage? 40 thous squish is cutting it close with a stock crank and rods.
Thanks,
Bri
