66e with a B-Pipe!
TOBY
BNA
NashVegas
66e
I wonted to try and see if it would work/fit its a GP800 with 1300R non PV cylenders 84mm bore 62T totaloss pickup and flywheel, carbs are 46SBN running pumpgass. I had a yamaha B-pipe i sold the manifold bought a new SXR wetpipe manifold, me and a friend made the adapters i then drilled the water passages in them installed a .5 waterline and re drilled the pump that line feeds the manifold and a .375(OEM) feeds the headpipe. it was a fun project/cool. im also using 62t bedplates hope you enjoy
TOBY
BNA
NashVegas
haha put the wrong pix in first post so i added another one.
yamanube
This Is The Way
Staff member
Mandalor
I would imagine they are running BReed's mod cases, that pipe is exactly what I wanted to not sell my 66E setup. I couldn't get anybody to come up with a solution (even though both Brandon and Waterdawg told me they had a manifold designed that would work) so it unfortunately got replaced with a 61x motor. Let us know how it runs, I had the same idea with the Kawi manifold to help eliminate the bolt pattern overlap. Those look like Brandon's intake manifolds too, also my idea.
