I do a lot of them and never a complaint. There's not really any benefit to having excessive rotating mass in a jet ski drivetrain. I charge $65 and includes balancing, paint, and return shipping. Send me a message if you're interested.@speedysprocket will a lighyer flywheel make a big difference? The only experience I have with light flywheels are on turbo hondas, makes pulling out hard with a puck clutch due to the lack of rotating mass. I also own a kx125 and when ridding trails the engine is either on or off. Maybe because of the slip between jetpump and water it wouldn't be as bad on a ski. Let my know your thoughts and cost estimate on machine work. I suppose you would have to turn it down on a lathe then balance it.
@Nottjbarlow I don't know how close you are but if you need to weld something sent it my way or use my stuff.
so my project is moving along nicely. I just need to measure and shim the motor, finish the jacketed pipe and have another go at the waterbox. I think I'll have it running in a day or two. I'm thinking about pulling all my stickers off and putting them on my yeti so I can paint this thing. I really should have waited to turf it.
