For all you superjet geniuses
1. The bottom rubber stop on the bottom of the 62t (came out of a waveraider && pic below)... Can i cut this so the engine will fit or do i need to get a new stop from somebody/somewhere?? i can't find any info on it...
2. Engine mounts... do i need a set of 701 engine mounts? or can i use the stock 650 mounts??
3. I have a factory b i'll be putting on... any suggestions or tricks? or do i just bolt, drop in and tune?
Thanks!
Thanks!
