300/440/550 650 SX vs. X2 Pump question? Yes.
Snackem
Danger Zone
Colfax WA
Do you guys know will a pump from an 650 SX bolt onto an X2? I pulled them both off last night and forgot to mock them up :banghead:
Snackem
Danger Zone
Colfax WA
I know that they look almost identical but I was an idiot and didn't mock the SX pump against the X2 Hull so I'm not sure if the bolt pattern line up or not.
Snackem
Danger Zone
Colfax WA
The general consensus was correct as usual. The 650 SX pump will bolt right up to the X2, everything is the same, cooling line nipple, bolt pattern, even the bolts are identical.
Crab
thanks darin...noswad!
Seattle
Nipple, nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,nipple, nipple, nipple, nipple,
