Super Jet 62t vs 61x Not so braap
denmark
Hey .. just bought a SuperJet sn, with newly restored engine, new pistons, new crank, new cylinder head ..
The setup is 701 61x engine, riva cylinder head, 2 x 46 mm Mikuni carburetor, Factory B-Pipe, but it does not feel as quick as my old 701 62t, with b-pipe, blowsion cylinder head, 2 x 38 mm carburator ..
There are almost no power in the bottom compared to the old 62t motor ..
Any ideas?
I doubt the carbs being rather large would cause it to have no bottom end power at all (unless they are Buckshot carbs lol). I would suspect they aren't tuned right.
Find out exactly which carbs they are, find out how they are jetted right now, then go to the carb jetting thread in the tech FAQ and find a comparable setup
denmark
its a dual Mikuni sbn 46mm will cheack the jets later..
but plugs has a nice light brown color, so think the jetting is okay..
Bobert540 : What size jets do you run, and what needle and seat? and your setup ;)
But is the 61x engine as good as the 62t engine?
Bobert540
Rockford,MI
I am running Dual 46 Blackjacks on a 701 bored out to 84mm and ported so I don't think my jetting will help. The 61x/61x is still a great engine, the more desireable 62t/61x is great but you can still do a lot with the 61x platform. Special FX on here is running a XS865 ss and a DASA 850ss on 61x cases.
This motor has 61X cases, yes?
You might pull both pulse lines off the carbs, put your finger on the end, crank the engine and make sure you're getting a pulse signal on each line. I'm assuming that a second pulse fitting has been installed in the intake manifold. This isn't straight forward in 61X cases with dual carb manifolds. It's very possible that the second fitting has been installed blind and is getting blocked from getting a signal.
denmark
Yes 61x cases and cylinder.. It has an riva intake manifold, i Will try to test pulse signal.. If i only Got one working pulse line, Can i Then use a T "adapter" ?
First, check if you have pulse signal on both lines.
If not, tee them together to the one you have signal on and try out the ski on the water.
If that fixed it, then take the intake manifold off and fix the problem with the second pulse fitting.
denmark
Hey again.. got pulse from both lines.. other i can check? can it be my one way valve, because just find out there is not fitted any one way tank valve...
Sospikey
Trying to get upside down
Sweden
I'd say thats a big problem. Get a valve right away! What's the compression? Is it hard to start?
