62t reed spacer QUESTION
maryland
Does anyone know the thickness of a 62t reed spacer I am sure there is a couple diffrent sizes but what works the best.
#ZERO
Beach Bum
Florida - U.S.A.
Reed spacers reduce the primary compression ratio by increasing the crankcase volume and they're really not needed unless you're installing longer reed cages or have a reed turbulence issue.
INDebtSJ
Having a VISION!
Ga
Is it normal to run reed spacers for v force 2 reeds?
I have a pro tec manifold now and it has my carbs hitting the stock exhaust tube.
I dont think I could get one to fit.
