Reed spacers reduce the primary compression ratio by increasing the crankcase volume and they're really not needed unless you're installing longer reed cages or have a reed turbulence issue.
Is it normal to run reed spacers for v force 2 reeds?
I have a pro tec manifold now and it has my carbs hitting the stock exhaust tube.
I dont think I could get one to fit.
