I rebuilt/jetted my carbs last night and went to get everything back on there today and had some problems getting gas out of my second line.
I have a 760 from a WB2 in there with dual 38MM Mikuni SBN carbs. My reserve pickup is reaching all the way down into the tank with around an inch of clearance from the bottom. The other line is chopped just as soon as it enters the fuel pickup cap. It doesn't go into the tank any further than the inside of the cap.
There are two lines coming from the tank total... One goes into the rear carb, then there is one line connecting the two carbs together, then the other line is going into the front carb from the tank.
Am I a retard? Is this a return line or did my other pickup break?
I didn't build this one up.. so I don't know everything about it. I bought it as it was. It was running fine until a few weeks ago when it was only starting and running for a quick second and then immediately flooding when I would give it any gas and shutting off.
I figured the plugs were just fouled and the carbs were giving it too rich of a mixture. So I cleaned and rejetted and changed plugs. But maybe it is my primer. There is a primer in the line going to the rear carb and I think it is broken.. it won't suck anything up. Just pulls back in like it is clogged.
Any advice?
Thanks in advance
Any advice?
Thanks in advance
