- bayarea, ca
So I was pulling my cases apart and found a nice crack in the bottom of the case. I need a new bottom case, however I noticed 6m601 stamped on the bottom case, top case says 62t. So is it possible to use a 650 case on the bottom? 6m6 was the 650 motor right?
also how do you tell if crank bearings are good?
