- Texas
What Exhaust System are you running?
The MSD Enhancer would require some fine tuning (Carb Adjustment Screws) versus the Stock CDI. The MSD Enhancer has more Timing Advance which requires a little more Fuel at the Low Adjustment Screw. And if the Engine is revving higher due to an A/M Tuned Pipe and/or Flame Arrestors, more Fuel up top.
The Front Cylinder running hotter could be caused by a Front Crank Seal Air Leak. Crank Seals are a wear/consumable item as the Crank spins and wears the Seal Center over time. Most don't think about NEW Crank Seals breaking-in or wearing-in to the Crankshaft. That's why Grease is required at the Seal Inner Lips.
If you remove the Flywheel Cover and there's a pool of Fuel at the bottom, then the Seal is leaking. Can also do an Air Leak-down Test to find any an all Air Leaks.
You will find that 2 Stroke PWC Carb Tuning is a lot trickier and fickle then Land-based Vehicles. Differences in Traction, Power Band and Transmission. I fine tune my Carbs every 10 degrees of consistent temperature change.
