next time you ride, take your FA off. see how it runs, if it runs better than you know you're too rich, if runs worse you know you're too lean.
not familiar with coffmans pipes but i know the factory pipe says to run a 145 main.
from what i've read, your idle is controlled by low speed screw, 0-1/4 throttle controlled by low speed jet. pop off pressure (N/S & Spring) controls transition from low speed jet to high speed jet. the rest is controlled by high speed screw and jet.
if your ski idles than i'd say your low speed jet and screw are fine. i'd toy with your high speed screw and pop off pressure.
if you need to turn out your high speed screw 3 turns, you need to increase the jet size.
I hope this gives you a starting point.
