- Boston MA
So I was never a big fan of the ebox sitting where the old oil tank was and it being held in by a rubber strap. I wanted it bolted down and stored more efficiently and wanted it to look clean. I made these mock up brackets from a 3D printer to see where the box would end up. Below is the first rev and they definitely need some changes. I am going to move the mounting forward and down so the fuse is still accessible and so it is not so close to the bottom of the carb, it is just to close for comfort(seen in pics). Also the final brackets I will probably cut out of 6061 3/16 aluminum with a water jet I can use at work. The metal will be threaded so the bolt head will be on the motor side unlike it is in the pictures, this also will make it easier to remove if needed with the motor in the hull. Has anyone else mounted a yamaha ebox in this location? If so please post some pictures I would like to see others peoples set ups. The only downside I see to this is water entering through the hood would dump right on top of the ebox, but I have a shaved hood so the amount of water actually getting in through the air vents into the engine bay is very minimal.
Corey
Corey
