- Asheville, NC
I was able to get this West Coast half pipe fitted to the 550SX but the cooling line routing is a little bit of a mystery to me.
I have routed the cooling line from the pump, into the fitting on the exhaust manifold. But I have a line coming off of the expansion chamber that looks like it runs to the bottom of the mid pipe. So I believe those 2 lines are correct.
That leaves the small fitting on the mid pipe that runs to the stock water bypass, and another fitting on the top of the adaptor plate. Lastly I think I might have installed the cylinder head backwards because there is 1 last cooling fitting facing rearward… something tells me this should be facing the front of the ski. Easy fix, but I need some advice on how to properly route these lines. Thanks!
