That is an old school trick to just glue the head to the cylinder to get those high compression numbers. The only problem with that is, the two mating surfaces must be perfectly flat to get a good seal, and even then the cylinder wall on a 550 is so close to the case stud holes you will still have problems. I would recommend a copper head gasket, especially if your over the stock bore. It will lower your compression some but will give you less trouble. check your compression again after the install and make sure both cylinders are the same or you have other problems as well
