550 build, couple ?'s, what do you think??
here is what i am thinking,
black hull
black hood
silver pole
camo turf
finger throttle
ODI grips
quick turn plate
lightweight subplate
500 gph bilge
clear fuel lines
rebuild motor
weld and true crank
bore cylinders (is there a limit on how much is to much?)
wiseco pistons
ported
pjs high comp head (190 psi??)
pjs exhaust manifold
pjs exhaust
DG tri y waterbox
44sbn carb w/ spacer
impeller? (looking for low to mid thrust)
ride technology oversized steering nozzle
ocean pro ride plate
jetting??
vortex flame arrestor
top loader intake grate
the majority of the parts for this build will be coming off the donor ski. i have already started sanding on the new hull but would appreciate some feedback before i get to far into the build. just so i only have to put it together once. the first two pics are from the donor ski and the final is the new hull
uncleuno
X-h20KC
OKC OK
I painted mine like a SXR black pole , black nose top , and the rest was red just remember its a 550 dont get crazy cause no matter what you do its probably only worth 800 to 1000 dollars. My paint job was 600 with paint now I dont even ride it. But it was fun building cause theres so many parts out there.Good Luck
Looks like you're going to have a pretty cool build project. You're looking for opinions, so I figured I go through some of your questions and build components.
1) As far as boring the cylinders goes, I think the largest you can go before the cases need to be machined for piston clearance is +1.5mm. Now that being said, you're aren't going to get any noticeable performance gains from boring to a larger piston. I would keep the piston size as close to stock as possible for that reason, and also for head gasket sealing. The larger the bore size you have, the narrower the sealing surface becomes between the cylinder and the water jackets around the cylinder. I've heard of quite a few guys having head gasket problems when the piston size starts to get too high.
2) Wiseco pistons are good pistons, don't get me wrong. however, because they are forged pistons, you have to be careful you give them plenty of time to warm up before doing other serious riding. Wiseco pistons have a big reputation to giving cold seizures.
- also, depending on whatever pistons you choose, make sure whoever does the machining accounts for enough piston clearance in the bore. Most machinists stick around .005", but that little of a gap in a piston port 550 cylinder with cast steel cylinder can also lead to a top end seizure. Most machinists are surprised, but cylinder to piston clearance should be around .007" for cast pistons (this doesn't include Wiseco, they are forged). I think Wiseco recommends to run them around .005", but you have to give adequate time for warm up or you'll be seizing the top end.
3) High compression head: unless you want the hassle and have the extra money to put race fuel into your ski, I wouldn't go over 180 to 185 psi. I personally would stick around the 175 mark just to be safe.
4) Impeller: all comes down to personal preference. My favourite all around impeller is the Solas KB-SC-A 13/18. It gives a good mix of power delivery throughout the power band. Aside from that I would stick to a 15* or 15.5* straight pitch impeller. If you are going straight pitch, steer clear of the Jetlyne impellers, my buddy had one that never seemed to stop cavitating. Stick to either a Solas or Skat Trak
5) Over-sized steering nozzle: if you're going to buy this, it's nothing worthwhile. What you would want is an over-sized reduction nozzle for the pump. You can buy one of those, or bore your stock exit nozzle at a machine shop. I think a stock exit nozzle on a 550 is around 65 or 66 mm. You can safely bore it out to 68mm. This will help with bottom end thrust.
6) SBN44: a 'must' to get your motor tuned in well. The old round body Mikuni is okay for a stock boat, but nothing else unless you do some internal carb mods.
7) Ocean Pro Ride Plate: I had one on my old 550 and loved it. It as always my favourite
8) Jetting: On my 550 with stock porting and a Coffman Climax 1/2 pipe with an aftermarket flame arrestor, I was running 100 pilot, 120 high at 15-16 psi pop-off pressure.
***If you want a lot more information, check out PWCToday.com in the Vintage Ski section of the forum. There is a wealth of knowledge around there for the old 550s. That's where I learned everything. If you go into the Vintage Ski part of the forum, there is a link at the top called the "440/550 Bible". It has a tonne of info on modding 550s. Everything right down to different porting specs.
You will find this site very limited for info on 550s compared to the other forum.
surfjetlouie
R.I.P. 11/27/2008
you may add my sponsons that I designed for the 550 hull. see fearlessnuts ski and picture in the carnage forum.
Mark Gomez
is where the surf is
Fullerton, CA
Screw that just buy it and all your work and expenses will be done for you.
No offense to surfjetlouie the hubbies work AWESOME but took some elbow grease to install. I bet that has changed though now, every product improves.
but really stop and buy my ski you can work on it or rip on it how it is. It will love you unlike other 550's.
-Mark
KR
www.krlines.com
Your going to spend more time and money building that 550 then it would to buy a completely built 550. Mark's ski is BUILT, better off getting his and using your 550 for parts. Thats just my take on it...
i pretty much have purchased all the parts already. just a few small things need to be paid for like bilge bracket, porting, carb, spacer, turf, and the jets. polish jet pilot reccomended a bigger bilge so ill upgrade that. i have a brand new mariner 17* impeller if anyone would be interested in purchasing or trading for a lower pitch prop, maybe something around 15*. thanks for the feedback and please keep it coming. will be posting pics soon
