247-PancakePete Front Foothold
Kennay
Squarenose for the _____
Myrtle Beach, SC
I know it's being brought up over and over, but I am missing it! doh.
How the heck would you remove, or bolt the e-box in place if you can't use the bolts through the back???
P
PancakePete
Guest
The glassed in version comes with a bracket with 2 bolts attached.
So alls you need to do is grind/cut off the nuts welded to the ebox
brakets, then you can glue/glass in the bracket that comes with it.
In post 2 there is a showing of the taking off the nuts.
You can also get the flanged version that can be screwed in.
I hope that clears it up.
there will be instructions with the foothold !
guiness92
But you dont need to remove the bracket when taking the ebox out. Or does it mount differently on a squarenose?
You can just leave the bracket bolted in like always, the ebox can still be removed without needing to ever touch those bolts.
P
PancakePete
Guest
True. But the what if the Bracket that holds ebox broke, and or the nuts that hold the ebox got corrosion on them. you could still take if off at the brackets.. if its glassed in without the new brackett, you would be beat.
you could glass it in over the bracket bolts, but there is always what if.
P
PancakePete
Guest
Cool design by the way!! Cant wait to see how the finished product looks!!!
Some will be shipped tomorrow and thursday, stop down there.
I will be helping with that and finishing my ski ! :bananapowerslide:
P
PancakePete
Guest
First Batch shipping out tomorrow AM ! :veryhappy:
P
PancakePete
Guest
so is it carbon or fiber glass? is yours just wraped in carbon?
If ordered you can get them with a Visual Carbon Wrap !
They are fiberglass... Its not worth making full carbon, for the half pound it would save. If that....
