24 7 Carbon Pole Pad
superjetruss
R.I.P. 5/23/2010
ANTIOCH IL
just got my x metal pole installed kit installed on my ski, but i ran into a slight problem. I have an old 24 7 carbon pole pad on my stock hand pole, and when i went to transfer this on my x metal pole, there are no mouting holes. I was thinking about drilling a hole through the tabs on the pole and bolt it in like stock style, but im afraid of cracking the tabs on the pole. Then I saw that warecraft factory makes on for the x metal pole, should i just get this one, or is there a way to mount my 24 7 pad wothout hacking it on!:banghead:
superjetruss
R.I.P. 5/23/2010
ANTIOCH IL
SO even if I bought the watercraft factory pad, Id still have to do the same thing?? what size should I drill the hole in the pole out to??
Y
yamaslut
Guest
the pole requires a bit of customization for the pad... that way you can fit yours to it.. I assume
Aquaholic
World's Oldest Teenager
San Diego, CA.
Speaking of chinpads....here's Wammer's new chin pad for the RRP. Pretty pricey!
I've got my OEM pad chopped down pretty heavily...still not real stoked with it
keefer
T1
Tennessee
Or use 6mm x 1.25 and keep it all metric. 6mm is a little smaller that 1/4 so not quite as big a hole in that small mounting tab.
