I have realized that this ski is too much for me and the style riding that i do at my age. I ordered it brand new fall of 2020 and completed the build on it over the winter of 2020-2021. Clean NC Title in my name as 2020 Superfreak. Only 5-10 tanks of 93 no E with Amsoil burned during Summer 2021. Ski was never beached, flipped, or in salt water and was stored in heated garage with a cover on it. Does not have Primer or Choke, starts Quickly and idles perfectly without either. Don't need to sell and will keep with the rest of my skis (3 RN SJ, 2022 GP1800r SVHO) if it does not sell. Will not part out, ski looks brand new. If you aren't interested in purchasing please move along and don't clutter up the listing.
New Parts Purchased for the Build:
2020 Glass Edge FR Hull (black and red)
RRP Ninja Chin Pad
RRP billet lite adjustable handlepole kit
New OEM SJ Steering Cable
Solas 148mm 12vane SS Pump stator
Solas pump cone and stainless hardware
Solas 148mm Stainless wear ring
OEM pump bearing and seal build kit
Skat Trak 148mm Mag pump big hub impeller
5mm cutback option for Mag pump
New SJ 90-07 length a/m driveshaft
JM Assemble pump stator with new bearings and seals, install driveshaft with premium synthetic marine grease, install prop and wear ring
(Total Solas 148 Mag pump build 1,661.90)
AdA Girdled Head (red)
Bilge with Bar Switch
148 Pump Shoe
Carbon Ride Plate
RRP lightweight pole bolt
HP Red Flame Arrestors
Odyssey Battery
Used Parts on ski:
HPE 809 Stroker w/ Mikuni 44s
SJ Ebox with MSD
B-Pipe
JM Water Box
Cold Fusion Tank
Thrust Trim, Lever, and throttle Lever
Riser Bars
Scoop Grate
Located in 28607
Can Ship in crate via truck freight for shipping costs.
828-773-5728
$17,500.00
More Photos tonight or tomorrow
RRP Ninja Chin Pad
148 Pump Shoe
Carbon Ride Plate
Odyssey Battery
Used Parts on ski:
SJ Ebox with MSD
B-Pipe
JM Water Box
Cold Fusion Tank
Riser Bars
Scoop Grate
Located in 28607
828-773-5728
$17,500.00
