2020 Rickter edge Fr white green/blue the red is vinyl sticker all new build RTR.
2020 hull all RRP pole,steering,straight bars, trottle lever, stainless steel stock superjet gas tank 4.7 gallon, new cables, new mid shaft, new driveshaft, couch mounts, fresh 38mm carbs, v3reeds, Fresh 718 62t/61x motor 180 on each cylinder, WSM crank, ada high compression head 35mm domes, B Pipe, MSD plug wires, MSD ignition enhancer. 144 solas mag pump, stainless wear ring, solas prop, RRP Trim RRP trim lever, Auto bilge 500 pump,RRP waterbox I’msure I’m forgetting stuff. All new build RTR 5 tanks of gas has been run through it rips. Will Ship 14,000obo will consider a superjet for partial trade. Also accept credit cards Contact Eric call or text 850-eight66-714zero.
